TwinTurbo.NET: Nissan 300ZX forum - 17.7v seems way off but let's reverify the measure. DO NOT
jzack
on October 15, 2017 at 8:27 PM
New Alternator and Battery still not Charging
posted by TheKryptKeeper
on October 15, 2017 at 06:57 PM
unplug any harness connectors! With headlamps on, car at normal idle what voltage reading do you get across just the battery + and - terminals.
TheKryptKeeper
18:57:35 10/15/17
17.7v seems way off but let's reverify the measure. DO NOT -
jzack
20:27:34 10/15/17
Re: 17.7v seems way off but let's reverify the measure. DO NOT
TheKryptKeeper
08:34:53 10/16/17
Re: Re: 17.7v seems way off but let's reverify the measure. DO NOT
TheKryptKeeper
22:19:02 10/16/17
Re: Re: Re: 17.7v seems way off but let's reverify the measure. DO NOT
NIVO88T
10:32:05 10/20/17
If the dash bulb and check relay are good. Measure battery
jzack
19:43:49 10/21/17
Did you check the ground wire off the battery? (n/m)
Brad(RI)
20:44:12 10/19/17
Re: Did you check the ground wire off the battery?
TheKryptKeeper
10:02:00 10/22/17
